1 - 1 of 1 Posts
'01 E320 CDI Sportline
I started a new post because i haven't found anything about this with "search" .
I need to change the D2R factory installed xenon bulbs on a 2000 W210. But i don't know how to get the bulb out. I pulled that black plastic protective cap, then the electric plug, but i stopped at pulling the bulb out. I didn't noticed some standard mechanism like the one for high beam halogen (some sort of spring that u can squeeze and loose the bulb), instead i see 3 or 4 philips bolts. I must unscrew those bolts or is way simple?
Thank you.
1 - 1 of 1 Posts
