One of my headlights went out and I bought the bulb from the dealer. I know how to take off the cover but Im not to sure how to but the new bulb in. Anyone know how?
2000 c230 Kompressor (Totalled 5/2012)
First, don't touch the new bulb, any oil you get on it will shorten the life significantly. If I remember correctly, there's a clip that you squeeze and then the bulb can come out. You might have to twist the bulb (I think it's a bayonet type). Also, there are some headlight aim adjustment knobs in the general area. Be careful not to touch them. I accidentally did when I changed my headlamps last time and I screwed up the alignment. But it's not easy to do unless you get careless like I did.
One of my headlight bulb went out and I bought the bulb from the dealer. I know how to take off the cover but Im not to sure how to but the new bulb in. Anyone know how?
Just turn the socket, i.e. the thing with wires attached. You can feel your way down the wires to the socket. I your hand will fit, the socket can be seen, but it might require a mirror or standing on your head or something.
No question this process draws blood and creates bruises--as on most cars.
1994 C220 (W202) Classic and 1998 C240 (W202) Elegance
Hi Guys.... I have replaced the bulb a few times on my W202's. The last time I did this the clamp that you have to squeeze completely broke off. I'm wondering if the clamp is needed (ie: some sort of negative/earth terminal to complete the circuit).?
Basically if I just plug the new blub in (without it being fastened in place) it does not light up.... does that mean the new bulb is faulty? A fuse is blown? or that the bult needs to be clamped in place? (the bulb on the other side works and the fog lights work on both sides - so I didn't bother to check the fuse)
Thanks for your advise in advance
1995 C220
I wish I had a picture to show you, but most of these bulbs have a wire clip that you simply unhook and hinge out of the way. The wire clip lays against the base of the bulb pushing it down into the opening. Many people think you need to remove the screw that holds the wire clip, but it is unnecessary. Push on the wire clip towards the bulb, and while still having pressure on it, move the clip sideways one way or the other to unhook it, then release pressure and swing it away from the bulb. Out it comes.
