I just replced mine to day, it took me 30 minutes including vaccuming under the console
here i hope this will help you to DIY.
First, take the small rubber mat just right in front of the shiffter, you can lift it up by your finger.
Second. pull out the shift knob and take the surround case.
since you already take the bucket out, you can simply push the wood console from under. I wish I have a camera so i can explain a little better.
After lifting the wood console you can easily see the wiring harness of the switch as well as the harness for the cigarettes lighter. There are 5 different size of connector, connected to the switch but you can't go wrong they are different sizes.
After removing all the harness you take the old switch by unsnapping the 4 tabs two in front and 2 at the back, replace with the new one reconnect the harness test it before you put the console back, to make sure it working. thats it and your done.
