1 - 15 of 15 Posts
2004 Mercedes-Benz S55 ///AMG, 2006 Mercedes-Benz E350
Sorry if this question has been asked a few hundred times. What would I use to remove wax from a small area to apply touch up paint, etc.? clayiung would not do this, would it?
Thanks.
Thanks.
Isopropyl and Water. 1:1 ratio mix. Mist over area and whip off. It'll make sure you don't have any residue from old waxes or polishes.
Cheers,
Nick
Wouldn't alcohol dry or damage the paint while removing the wax? How about a mild polish?
2001 Mercedes ML55 AMG (Silver)
Prepsol. Available at autozone. about $6 a can
2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Y'all gonna kill me...
Ummm-try AJAX Dishwashing Soap :eek:
"Dedicated to BENZ RIDER"
Goop Removes Wax
ANY Degreaser Removes Wax
Isopropyl Alcohol
Polishing Compound
Thanks.
1987 300D Turbo (RIP), 1995 E420, 1993 400E
I've had great luck with a dawn dish soap/amonia solution. Prepsol works good too!
Aaron
2005 230 Kompressor
Prepsol, good stuff. Will remove all wax with no harm to the paint. I have used it on my wife's cheap plastic computer case to remove residue and it did not etch or stain the plastic. Seems to have more bite that a typical mix of alcohol and water which also works, but Prepsol works better.
1999 SLK230 Sport
I have used Prepsol before and it does the trick, however, for the money, you can't beat Dawn.
00 SL500 SOLD, 05 SL600 Sport, 09 Silverado 4x4 LTZ,SOLD '15Silverado LTZ 6.2 8Speed John Deere 318
Why go buy a gallon of Prep-sol, when 2 drops of ANY dish det. or DRY GAS (alcohol) will do the very same thing? EVERYBODY has dish soap!!!!!
Discussion Starter #13
I would think if polish removes clear coat and paint, it should remove unwanted wax, which is the top layer over clear coast and paint.
PROUD OWNER! 2002 slk32 AMG
the issue with using polish to remove wax is the wax builds up on the pads and clogs it. then you have a mix of polish and wax which isnt what you want. the dawn cuts the wax and removes it
1 - 15 of 15 Posts
