1 - 18 of 18 Posts
SL550
E-Class W211 front bumper removal (standard body style).
Tools needed:
- Automotive wheel ramps (Rhino ramps from Autozone).
- 1/4" drive socket set with 8mm and 10mm sockets.
- #20 torx bit.
- Floor jack, optional but useful.
- Flat blade screwdriver.
Instructions for bumper removal:
1) Turn front wheels full right to remove push-pin fastener at lower front corner of left wheel well plastic splash guard. It's difficult to remove this fastener once the car is up on the wheel ramps.
2) Turn front wheels full left to remove push-pin fastener at lower front corner of right wheel well plastic splash guard.
3) Drive car up on wheel ramps. Block rear tires. Open hood.
4) Remove lower mesh plastic grille. There are five attachment points on the top edge of the grille. You can get to three of them with your hand by reaching between the radiator and the back side of the grille. The two outer ones can be released with a screwdriver also reaching in between the grille and radiator. Once the plastic tabs are released, you can remove the grille by pulling it out from the front of the car.
5) Remove the plastic panel located immediately behind the bumper from the bottom of the engine compartment. This panel is held in place with nine sheet metal screws with a 8mm hex head. Five screws are on the bottom of the car and there are two screws in each wheel well at the inner lower edge. After removing all nine screws you can work the panel free.
6) Disconnect the cable from each fog light and remove both fog lights. They are held in place by two sheet metal screws with a #20 torx head.
7) Remove the side marker bulbs. The one on the passenger side turns clockwise to remove and the one on the driver side turns counter-clockwise.
8) Remove the temperature sensor from its socket on the driver side.
9) If you have a floor jack, raise the car at the jack point on the cross member below the engine. You do not want to raise it off the wheel ramps. But it helps to have more clearance above the tires to work in the front wheel wells.
10) Remove three of the plastic nuts holding the forward half of the plastic wheel well liner in place. It's not necessary to remove the plastic liner. You just need to loosen it up so that you can pull it away from the fender to gain access to the screw and bracket securing the bumper to the fender.
11) Pull back the wheel well liner and remove the sheet metal screw from the rear end of the metal bracket . There is only one sheet metal screw (#20 torx head) holding this bracket in place. Don't attempt to remove the bracket yet. I used a #20 torx bit in a 1/4" socket with a 6-inch extension for a 1/4" drive wrench. The head of the screw faces the ground.
12) Remove the 5mm bolts (8mm hex head) holding the bumper to the headlight assembly between the small lens and large lens (both sides).
13) Remove the two 6mm bolts (10mm hex head) on either side of the large grille area opening.
14) Remove the two 6mm bolts (10mm hex head) securing the bumper to the bottom edge of the crashbar. You can access these bolts through the front where you removed the plastic mesh grille.
15) Remove the three 5mm bolts (8mm hex head) holding each headlight assembly in place. Two longer bolts are on top. One at the rear outer corner and one at the front inner corner. The third bolt is accessed from the bottom. It's in the area above the fog lamps. You don't need to disconnect the headlight cables and remove the assembly. But it helps to allow the headlight assembly to "float" freely while you disengage the bumper from the fender.
16) At this point all of the fasteners holding the bumper in place have been removed. The only thing left to do is to remove the two brackets "clamping" the bumper cover to the lower front edge of the front fenders. Before you do this, position some cardboard boxes, bags of packing material, six packs of paper towels, or other suitable items to protect the bumper in case it falls off the car.
17) The bracket holding the bumper cover to the fender has a "pin" that slips into a slot at the front edge of the bumper cover. There is a matching slot near the front edge of the fender. It's not possible to see this pin from the bottom of the car. Use a flat blade screwdriver to pry the bracket away from the bumper/fender and towards the center of the car. The bracket will "hinge" on the pin at the front end of the bracket. After you swing the bracket away from the bumper, you need to slide it forward to remove it from the slot in the bumper cover and fender. You will probably scratch some paint off of this bracket with the screwdriver. I recommend repainting the scratched areas of the bracket before reinstalling it.
18) After removing the bracket from each side of the car you need to deal with the small plastic "hook" holding the bumper cover to the very front tip of the fender. This hook is an integral part of the bumper cover. Disengaging this hook from the fender is probably the most difficult step of removing the bumper. Simultaneously raise the head light assembly slightly, push the leading edge of the fender outward slightly, and push the bumper cover inward toward the headlight assembly. Don't get too aggressive with the fender. It's aluminum and you will make a real mess if you apply too much pressure on the fender. It took me about 20 minutes to free each side from this hook. It should take you less time, since you now know that the hook exists!
19) Gently pull the bumper forward and away from the car. This is one step where a second person would be helpful. But I did manage to do this step alone. There is a "pulley" like attachment point on each side just below the fender/bumper seam.
To re-install the bumper, reverse the order of the steps above. When re-installing the bracket between the bumper cover and fender, I smeared a thin coating of car wash soap on the bracket to facilitate snapping the bracket back into place.
BenzWorld Sponsor
CLK320 2005
this DIY is an awesome article
good job mate
[:D]
I can't download the images. I get a bunch of jumbled characters but no photo. Any links to the photos with step by step removal?
You mean you have the same download problem? I'm not aware of any restrictions at the forum to download images once you have registered.
Is it still the same with the attached photo (I've downloaded the first photo, renamed it to use a shorter name without special characters and posted it again)?
Tools needed:
- #20 torx bit.
embedded the pics for those having issues with the attachments
:thumbsup:
I plan on removing my front bumper this weekend (E55 front conversion), and this DIY will help tremendously :)
I'm having trouble re-inserting this bracket. When re-installing this bracket, do you re-install it on the car (on the fender) or does the bracket have to be on top of the bumper skin, then place it into the fender? Any tips on how to snap it back in?
Super Moderator
Mine was on the car, but I had help at the body shop and they showed me how many
pieces there are on these bumpers when mine was cracked and replaced be the
utility company.
2005 E320/2006 R500/2007 E350
I replaced the headlight assembly on our E350 after it had a run-in with a deer hoof. These instructions were a big help. I dropped the bumper cover from one side only so I didn't have to mess with that crazy bracket two times. Thank you for posting the how to.
E500 wagon & GL450
Fantastic instructions
I hope that everything I need to work on or replace on my w211 has been performed and documented by you. These were great instructions with the needed details for sizes of screws and the size and type to remove them. Thank you for making my life easier.:bowdown:
2003 E320 Sport
How long did it take you to remove and reinstall the bumper? Pulling mine tomorrow and I want to make sure I set aside the proper amount of time to perform work.
Super Moderator
I did mine in 30 minutes off and 20 minutes back on.
I successfully removed and reinstalled my bumper last night. These clips were by far the worst part.
I got them back in by looking through the fender so I could see the bumper and fender tabs as they went into the clip. Make sure the lower layer of bumper tabs are making it into the clip. Once the bumper and fender edge are in the clip, the steel 'handles' that poke up from the clip are then used to pull the clip towards the wheel well and lock it into place. The torex screw then can go in to secure the clip.
1 - 18 of 18 Posts
