I need to remove starter on 560 Sl and found that I can not get to top bolt. Any directions and advise on how to get this job done will be greatly appreciated. Thanks
Discussion Starter #2
Ray,<br> <br> You need a 10MM hex 3/8 socket, a 3/8' universal, 3/8'-18' long extension. Try to locate the 10MM hex with the universal attached to it into the socket head bolt from the right side of the transmission (you have to work from underneath of the car). After putting the hex into the socket head bolt, attach the extension and try to loosen it. Make sure the hex key sits properly into the socket head bolt.<br> <br> Good luck,<br> Kevin
Kevin<br> <br> Thanks for the info. Turns out that it was a bad cable connection at the starter. Will keep info as I probably will need it someday.<br> <br> Thanks again<br> Ray<br> <br>
