I need to raise the fuse box to look for a dropped screw. I removed the two nuts on each side of the fuse box but it is still tight. Is there a hidden fastener, or maybe a release catch of some kind?
Thanks,
WXW5
89 190E 2.6 x2
Last year I parted out a 190E and if I remember correctly the fuse box is secured from the inside of the car as well. You'll need to remove the kick panel under the driver's side dashboard and then there should be access from below to the fuse box screws.
