1 - 9 of 9 Posts
1986 560 SL
Can someone please tell me the secret to removing the bulbs that light up the HVAC controls on a 560?
I've pushed, pulled, turned in all sorts of combinations with no luck.
The glass part just pulls straight out of the white plastic part, unless someone glued them in or they melted from being the wrong bulb.
1986 560 SL
Thanks John.
I pulled as hard as I dared w/o breaking the bulb.
As it happened, all the fiddling around got the bulb that was out working again.
1973 450SL 2004 E320 4Matic Wagon 2019 Jeep Grand Cherokee
Problem solved. Heck of a deal
Thanks John.
Are you trying to prove ConorD's point? Fiddle with it and the problem goes away?:)
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Next time try to slip a piece of shrink wrap tubing around it to give you something to grip.
Len
1986 560 SL
Discussion Starter · #7 ·
Len
Do you heat shrink it?
I grabbed it gently with a pair of pliers but I was waiting for that crunching sound of breaking glass....i
Use an old bulb. Place heat shrink on old bulb. Apply light heat. Shape to fit and remove gently. Viola, bulb tool.
No, you shouldn't have to shrink it if you use the right size.
Len
1 - 9 of 9 Posts
