1 - 8 of 8 Posts
I'm using a madlife garage engine oil dipstick made for MB's to check the engine oil level in my 04 E500 4matic. at the end of the dipstick
it has numbers from 50 to 200 . it did not come with instructions. when I checked the oil level when the engine was warm , not hot it had a reading of
110 . any one know if this is the correct level for the engine oil ??
2000 SL500, 2001 S600, 2004 E320
How much oil did you actually add so far? Are you sure this dipstick is getting to the bottom of oil pan?
According to WIS document for M113.967 oil level is Minimum 132mm and Maximum 149mm. At 110mm you would be off the chart, more than 3L short of correct level.
the dashboard says the oil level is normal , although I'm thinking it's a bit low from the dipstick reading
1 - 8 of 8 Posts
