You could have a clogged tank strainer, clogged filter, bad fuel or a clogged line or banjo bolt. You should drain your tank first, fill with fresh diesel (at least half a tank), and replace both filters. If you have compressed air, once you have the old fuel out, you can shoot compressed air in to the line that returns to the tank. That usually blows out the strainer and pressurizes the system. The you should hear your pressure relief valve hiss but should not see any fuel leaks. If you do not have compressed air, you can remove and clean the strainer with a 46mm bolt. The strainer can be found at the bottom of the gas tank, under the car, behind the rubber damn. There is a screw in fuel line going right up into it.
Once you have put fresh fuel in, replaced both filters (fill the filter with fresh fuel), cleaned the strainer, you can then pretty easily assess where your fuel issue is. I am sure it is bad or clogged fuel between the tank and the spin on filter. I recently had a no-start and I checked each inlet and outlet and return at the spin on filter while someone cranked the motor. Turned out it was a clogged banjo bolt from the filter to the IP.
If you have good fuel going in and out of the filter and returning to the tank, you should be able to start it. It will take about 45-60 seconds of cranking/priming.
Like mentioned above, also have a friend crank while you crack each of the five injector lines, one by one (crank for 10 secs, then close. Repeat.) Then, if you're glow plug system works, I am sure you will have a start.
Don't burn out your starter! It is a pain to replace.
