1 - 8 of 8 Posts
2004 SL600; 2004 SL500;1996 SL600;2003 ML350; 1997 C280 Sport; 1987 190e 2.3 16v; 1986 190e 2.3 16V;
Found it in the trunk. The other side is spring loaded. This had a spring as well but I can't get the thing to lock in.
Trurcks or do I need a new part?
2006 SL600
They sell repair/upgrade kits for this flap on eBay. Good thing you found the flap - it’s not sold separately from the larger trim piece.
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
I used a trap of elastic and rivets to attach it to the flap and the trim panel. It acts as a spring and also keeps it attached so it doesn't go flying away.
Ordered a kit. Thanks
Discussion Starter · #6 ·
On ebay, search "R230 flap". He sells multiple options. Left only, right only, both, also hinge kits, and also everything for one side
Reactions: Rugger-fly half
2004 sl350
On eBay search "R230 roof flap repair"
The Seller is me, Jaguartvr. I can supply just the repair hinges or a replacement flap trimmed in black complete with a replacement hinge if you have lost yours.
There are others available on eBay but they are just downloaded from a free 3d printing site, they do not work and break almost straight away normally resulting in the loss of the flap.
I can only currently supply the flap in black. If there is anyone near Egham, Surrey who needs a flap in a different colour I should be able to help you but I need a sample to match.
I also offer a fitting service.
2004 SL600, 1960 Triumph TR3, 1963 Chevy Suburban + others
Thanks.. I would need a silver one.. I've also jerry rigged what I have and it seems to be working..
1 - 8 of 8 Posts
