1999 E300 and 1973 450SL
Does anyone have any ideas on how I can configure the electrics to have a position where just the foglights are on in my 73 450SL.
1973 450SL-1968 911-1994 840ci-1967 Mustang
Seems I remember this being discussed previously. You might try a seach and see what comes up...
1988 560SL (California Model)
Probably not without adding its own separate switch and circuit. Something like you'd do on an off road jeep or 4 wheel drive if you wanted to add lights.
My suggestion would be to get a used headlight switch and figure it out.
Some wire and an additional relay....it can be done.
OR you can put a nice MB toggle (rocker) switch on the dash or console and wire them independently....removing them from the system and adding a relay.
As other members suggest, you could arrange any combination of fog lights you wish with separate relays, control switches and control modules.
