1 - 12 of 12 Posts
2007 CLK350
I started having a problem with the washer fluid not spraying a couple days ago, that started happening right after I filled the reservoir with Rain X. I am almost 100% sure it is clogged. Any ideas on how to fix this on my own? Or, if I take it to the shop, how much would it cost me, roughly?
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Will the washer operate with the hood open? i know the wipers won't. The pump motor is located on the bottom of the reservoir, behind the front bumper, driver's side. You can access it by removing the fender liner extension that sits between the wheel and the bumper. It's easiest to remove it with the car lifted and front wheel removed, but ti can be done on the ground with the wheel turned.
2004 CLK 240 Coupe
Okay, just tried this. No sound came out of the washer reservoir area. Is it a fuse problem?
Sorry - that was bad information from me about the test.
The pump has no 'external fuse'. It has 'electronic fuses' on the front SAM which controls the windscreen washer pump and the headlight washer pump (if fitted). Similarly the external lights have no fuse-box fuses.
We know that these washer pumps die occasionally. Just remove it from the reservoir and check it. They are not expensive.
2007 CLK350
Discussion Starter · #8 ·
Okay thank you. Could you give me instructions on how to remove the washer pump and how to test it?
1 - 12 of 12 Posts
