OK, so maybe I didn't "fix" it, but here's the story. I drove the '00 S500 to Florida this weekend, and on my way back to the hotel Saturday night, the right front Airmatic struts starts leaking profusely. At this point I'm 800 miles from home. I'm close to the hotel, so I limp it back. The compressor would keep up with the leak while it was running, but when the compressor would cycle it would drop and the tire would rub the inner fender until the compressor could kick back on. So basically it would go back and forth between rubbing horribly and not rubbing every two or three minutes. I jack it up and devise a plan. The next morning I head out to home depot.
Step one: Jack up the car a little.
Step two: Insert 2"x4"
Step tree: Lower the jack, sit back and revel in the absolutely perfect ride-height.
The ride was a little bumpy, but really not that bad! It really wasn't much harsher than it is when you push the button that stiffens the suspension! I made the 800 mile trip home with ease, and never had to change or replace the block of wood. I got a few extras just in case.
Thank you, Thank you, Thank you 16vCorey!!! :grin
I am SOOOO glad I read through your post and the ensuing thread prior to taking a trip from Orlando to Savannah, then Atlanta and back home to see our new grand kids. Early in my trip, the front end would occasionally drop, but then pump back up. I made it to Savannah OK, but I needed to make wide turns so the tires wouldn't hit the fenders. Naturally it got worse going to Atlanta (also had a flat tire on route), but when I got to my daughter's house, I could hear hissing from the left front strut. I just replaced that one a month earlier, plus both rear struts earlier this year, and a new pump one week earlier! I was in Air Strut HELL!!!
Well, the brass connector at the top of the strut, where the hose connects, had broken from where it threads into the strut top. I found a used replacement from a salvage yard on a Saturday and replaced it. But it was still ballistically hissing at the lower portion of the strut.
My initial plan was to drive the 400 miles back to Orlando on Sunday, but if I had it fixed in Atlanta, I wouldn't be able to begin looking at options until Monday, which would drag out with shipping and who knows what it'd cost. Since my relatively new strut was under a lifetime warranty, I built a similar block and secured it to my upper control arm and rounded the top corners off to try to match the underside contour of where it's be touching, and used two wire ties on each side for insurance. It's a good thing I gave some tools to my son-in-law last Christmas! See the pictures below.
Riding the bumpy roads around Atlanta, I was concerned that would tear the wood block off, but it didn't! Driving on the interstate was very smooth and we got home safely. My first phone call of the next day was to RMT and I couldn't believe how quick they offered a warranty replacement. He said I'd have it in 48 hours, but I got it in less that 24 hours. It was a simple swap out and appears to have resolved much of my air strut issues!
Thanks again, 16vCorey, for posting your ingenious "Hillbilly" fix, as my son calls it!
Best,
Russ
