1 - 8 of 8 Posts
I’m changing rear brake pads on 2015 S550. After the brakes have been put into service mode and it’s time to compress calipers does it require a tool that will compress and turn it or will a tool that only compresses the calipers work? Thanks.
1989 W124 260E
You can purchase a brake piston wind back tool from ebay . Myself i use a large G clamp . But some pistons need screwing back in to the caliper .You will identify these though the 2 holes in the piston crown i have the end of a pair of c clip pliers ground down to fit inside the holes inside the caliper crown. Dont forget to remove the top on your master cylinder and keep an eye on the fluid level .As you push or wind back the piston the fuid will return to the catch tank and over flow in some cases.
2002 SL500 Silver Arrow; 2005 CLK320 cabriolet; 2008 E350 4matic; sold 1985 380SE
What is typical timeframe for replacing brakes on this car? I purchased a 2016 S550 4matic with 36,000 miles in May 2019. The brake pads were replaced at 18,600 miles. Brake fluid was flushed/changed at 20,500 miles. The car had a 10,000 mile checkup at 28,000. It is now due for another routine checkup with 39,000 and today the brake pad warning light came on. This is my sixth Mercedes and I have never changed brake pads that often?
1989 W124 260E
BeardSL To start with you need the information that you will find in a workshop manual.The brakes are are a safety factor, and they need to be done the right way , for your sake as well other road users . If it was me i would go to youtube put in what your looking for and as a rule you will find it in a video form, just how this job is done . Pelican Parts have a good - How To Do It section .
2015 S550 4MATIC
Getting ready to do mine. I have 2015 4Matic S550. Doesn't putting them into service mode (dash) retract or compress the piston in the caliper? If not, what is it for. Did you find any videos?
I was recently changing my rear protors and pads today. I was wondering after you reset brake caliber did you still have to turn the piston back in. I could hear mine after i did the reset but the pistons still aren't in far enough to actually put caliber back on with new pads
1 - 8 of 8 Posts
