1 - 10 of 10 Posts
1999 ML320(mine) and 2004 ML500 (mothers) and 2007 GL450(fathers)
On my dads car, 2004 ML500, the rims have some black break dust build-up. I have tried using soap and water, but that didnt work. Then I used some windex which worked with my ML rims but this still does not work. On my final hope, I tried our power washer on it and even that only took off a little of the dust. Does anyone know how to clean the break dust off of these rims. And also why is it easier to clean the 1999 rims then the 2004?
'01 ML55
PS21 wheel cleaner. You may have to let it sit for 15 min, but it does the job. You can also use a soft abrasive sponge, ie; kitchen sponge. DO NOT use SOS pads or anything with metal etc.
Lot of so-called rim cleaners are acids. They will clean the dust fast and easy, but might eat something you don't want to be eaten.
Simple Green is having automotive formula. With gentle Scotch pad I was able to remove all dust.
Get some elbow grease, while you are on it.
Mother's Aluminum and Mag Polish
I use Mother's Aluminum and Mag Polish. Its a cream based. You just rub it on with a clean cloth, let it break down the brake dust, then rub off with a different clean cloth. Its the best cleaner and polish I have ever used. Also..a little elbow grease is required.:)
2004 SL500; 2003 E320; 2001 ML430 Sport; 1999 E320 Wagon
Clean rims
I use Rotex Gold pads.
But the best way to clean these wheels is with really HOT water. :eek: The dealer uses a steam cleaner with no soap. I just use hot water and some Simply-Green. Spray on some green, let sit, then use a sponge soaked in wicked hot water. No scrubbing, no serious chemicals to crack the clear coat. The black-stuff wipes off. If it you don't wait so long between cleanings, the S-Green isn't necessary.
1998 ML 320
Just curious...
How long have the rims been left dirty since last cleaned?
1 - 10 of 10 Posts
