1- Heavy smoke at a cold start is usually a bad glow plug, often accompanied by rough idle for the first 10-30 seconds. Check your glow plugs with an ohm meter, at the relay, with the harness disconnected. Each terminal at the connector (to ground) should be 0.6 ohms, or at least less than 1 or 2 ohms. Anything higher indicates a bad glow plug. <br> <br> <br> 2- If the glow plugs are all OK, you can disassemble & clean the injectors. A diesel shop will probably charge $75-$100 to do this for you, as well as set them all to the correct opening pressure ('pop' pressure) with internal shims. I'd recommend pulling them out of the engine yourself, but having a pro diesel shop actually disassemble & clean the injectors. If you still want to do it, there is a procedure in the MB service manual with pictures that explains how. If you don't have the manual, try to buy one, it's worth its weight in gold for a DIY mechanic...<br> <br> <br> HTH,
