Dang! Another reason I regret giving up cigars.
Thanks for the post! This trick may come in handy.
pretty cool; i use a halloween fog machine
I thought of using Halloween Machine ( Party smoke Machine). Did ever use it? Does if generate enough pressure to check enough smoke leak? Much safer than Cigar. No second hand smoking at least.
Sahai
ive been doing the cigar test on my diesels for years, ive found a ton of vacuum leaks this way, if you use a really long hose 6ft or so you can be in the cabin and look in there for vacuum leaks I dont see any reason a Halloween smoke machine could not be used for this.its great way to test switchover valves too.
