old school
the best advice i got from this thread and
This one is get your car warm, further on i tried everything, but my car still had some air in the system. So here is what i did:
1)Take the top radiator hose off
2) fill the system till the water starts coming out of the top ventil of the radiator
3)conect the top radiator hose
4) Warm up your car with the cap off
5) When the car is warm (about 81 C) get in to the car And turn on the heater (red line) on max
6)Cool air will be followed by warm air
7)Call your friend and tell him(her) to look at the level and fill when needed
8) give it some gas, keep the car at 3500 - 4000 rpm for about one minute 9depends on the level
9)turn the car off, put the cap back on
10) Take a small screwdriver and unscrew the bracket by the termostat (top hose in most cases)
11) DO NOT TAKE IT OFF, but put your screw driver just a bit under, when you c that only coolent is coming out without any bubbels YOU are good to GO,
12) tighten the bracket and let the car rest for a bit, then check your level, you might need to add a bit of coolent depending on the amout of air that you got, when slightly lifting the hose.
Make sure you got the correct level, too much and you got too much pressure -> high temperature
HOPE this solves your problems as it did for me
HAp
