1988 560 SEL
1988 560 SEL, 350,000 miles. I couldn't stear the other day when I went to the store. I bought power steering fluid, and find my power steering container completely empty. I fill it and start the car, and I have a steady stream coming out from the drivers side bottom of the engine at about the back of the wheel. I have not been able to get under it, but what should I expect to see? I know there are 2 lines, I am hoping it is one of them!
1991 300 SE
After reading this and your other post I think you just need to GL this as a parts car and start over with a diesel. Consider it a $2200 126 education. IMO 350,000 miles is 150,000 miles beyond what can be expected of a chassis before major component work is needed.
· Always Remembered RIP
1991 560SEC AMG
In its lifetime, this was what happened to my 560SEC.
The power steering gearbox on my 1991 560SEC gave out at 24,000 miles (warranty repair at Beverly Hills Ltd Mercedes Benz - the dealer), again,at 50,000 miles, and again at 101,000 miles.
The car has 124,500 on it now and no problems with that right now.
About $700 to have it fixed at an independent mechanic, a lot less if you DIY.
It is a consumable item, in these cars, so if it went for the first time at 350,000 you REALLY beat the odds big time.
Just fix it.
1993 300TE, 1995 E320 Wagon
It does sound like it's one of the lines to the steering box. Not too expensive a fix. It might be the steering box itself though, which is more like a $450 item (rebuilt) with another couple hundred in labor.
(From AutohausAZ)
Cohline/OEM Power Steering Hose; High Pressure Hose from Pump to Steering Box 1 per car. $71.20
Cohline Power Steering Hose; Low Pressure Return Hose; 12mm ID; Bulk
Please verify hose diameter prior to ordering. Sold by the meter. $13.15
I'm kinda with jdc1244, in that it looks as though you really need to have an honest assessment of the car by a trusted guy in 126s. It would be worth a couple of hundred to have a THOROUGH checkup, with the idea that a list of items could be set up, in a 1-2-3 priority order, with approximate prices, perhaps even split out as to parts/labor. Then you could make a better judgement about how much you'll need to get the car to be "whole" enough to at least be a daily driver, if that's what you want. If you can DIY for some of the items on the list, great-- save some money and really get to know this car while you're doing it. If, on the other hand, the list is too long, or the total price is too high, than I would agree that perhaps this was a lesson in 126s, as jdc1244 said. There are some really fine 126s out there, with far less mileage, in (apparently) better shape, for between $3000 and $6000. If your list looks like the car still needs $2500 or more to get into shape, then you'll be into it for $5000 or so (depending on what's been done thus far). You can see that you'll be playing a losing proposition if the list goes very far beyond the $2500.
As many have said here, get the most well-maintained example you can, even if it's $2000 or $3000 more. Complete service records and receipts (going back at least 10 years) are worth at least $500, maybe even $1000. "The most expensive Mercedes is a cheap one," or something like that. You may be on the short end of this one, and depending on how the analysis/inspection comes out, it might be worth considering it as a parts car for your next one (or to part out).
Good Luck!
Dave
