G
Valve adjustment and tranny fluid change with tranny adjustment ?
I would do the valve adjustment myself but I can't seem to find the the feeler gauge to measure the gaps in between.
Thank You
00 S500,99 4wgn,87TD
They will prob charge 2 hours + vc gasket on the valve adj. Trans service should be 1.5 ...
They will prob charge 2 hours + vc gasket on the valve adj. Trans service should be 1.5 to 2 hrs. also. Parts & fluid should be 75 -80 $$.....
G
Re: They will prob charge 2 hours + vc gasket on the valve adj. Trans service should be 1.5
80 bucks each or both ????? seems really cheap
1989 560SEL
BENZDOC
benzdoc-where are you located in NY? i see you have a 516 area code, like i did before moving to boston.
are you an MB mechanic, like your screen name implies? where? i will be back on long island for a couple weeks in december, and i may have some business for you....
janos z.
Re: Re: They will prob charge 2 hours + vc gasket on the valve adj. Trans service should b
$80 for trans filter kit and fluid. 10.00 for vc gasket up to 4 hrs labor total.
