87 Euro 560 SEL
I picked up fuel filters for my 82 300TD the other day. The gal looked them up in her parts book and then gave me 3 filters, 2 canister and 1 inline. I can find 1 canister and 1 inline on the car. The 2nd canister is smaller than the first. Where does the 2nd canister filter go or did the gal screw up? I can't find it in the manual.
2001 Volvo V40
It might be the tank filter, it looks a bit like a small canister. Under normal conditions that doesn't need to be changed. If it is blocked, you can clean it.
1984 300D
The one on the bottom of the Fuel Tank is a Screen with a 1-13/16 (47mm) inch flat nut on the bottom.
The Fuel Tank Screen can be cleaned and reused but you need to change the O-ring (and drain all of the Fuel out of the Tank before you remove it).
