1 - 20 of 53 Posts
W220 2003 Update S500L, W204 2008 C220 CDI
Unfortunately this is a long post but the subject is complex and confusing.
I still have several issues and these will be listed in the next post. Any help will be much appreciated.
If you are having trouble with your Chinese Star Diagnosis System (SDS) or are interested in getting one, the attached documents may help you decide what to do.
I produced my SDS quartet of documents after months of research and experimentation with a Chinese SDS after it stopped working.
Document 1. SDS What is it
Document 2. SDS Instructions For Connecting and Using
Document 3. SDS Software Installation Instructions
Document 4. SDS Transfer From External HDD to Internal HDD
There is some duplication in the documents so that each one can be used independently of the others.
I do not profess to be an expert in SDS, far from it, but I do find that keeping the important information in one or two documents in as simple a form as possible helps me in future when I have a need to revisit the subject. It may therefore be of use to other BenzWorld members. As always any feedback is much appreciated.
Be warned, purchasing, owning, setting up and using a SDS can be an extremely difficult project and one not to be undertaken lightly. There is a plethora of information available on SDS on the Internet but unfortunately it is mostly non constructive, quite often abusive, and fairly often not available without paying a fee to some very enterprising people.
My SDS as supplied came without any installation instructions other than a couple of crude videos and an out of date pamphlet for the RS232 Card. The SDS has inbuilt instructions and videos which are very helpful for using and understanding the SDS.
After a lot of assumptions and several emails to the supplier, I eventually got my SDS configured and communicating with my car and began cautiously testing the various functions and capabilities of SDS. I particularly like the Workshop Information System and the StarFinder and have used them several times to date. I have yet to have a real need to use DAS but began self training just in case, and progressed to the point where I could exercise the cabin lights (easy to watch from outside the vehicle) and got to the stage of opening and closing various flaps on the ACC. Since getting my SDS working again I have been able to read out the list of fault codes stored in my vehicle and erase them. The faults were mainly caused by me fiddling with relays and fuses etc. and removing the front seat to repair my seat heater and ventilation fans.
When my SDS stopped working it took me two months of research and experimentation to recover from my predicament. My most important and unexpected discovery was that the RS232 data link is temperamental if operated at the recommended baud rate of 115,200 bps. The laptop and serial adapter card worked fine but it seems that the MUX, RS232 to RS485 converter, or the car itself, could not cope with these high data rates. I have now set host and guest COM2 settings to 9,600 bps and the MUX is very reliable and connects every time. There doesn’t seem to be any penalty with using the lower baud rate. The second document contains my fault finding techniques using a free serial port monitor which I downloaded from the Internet. I used two separate installations of this application to watch the data traffic in both the Guest Virtual Machine environment, and the Host Serial Port through the MUX, while SDS was communicating with my vehicle. This was critical to the successful outcome, as without the port monitor you have no idea whether the SDS is communicating with the vehicle or not.
I also found the order in which you do things when starting SDS was important and I have listed the connection regime which has worked reliably every time since instigating it.
After the success with the above I became even bolder, and have now transferred the SDS application from the external HDD to the internal HDD. I partitioned the laptop hard drive and cloned the SDS software onto it so that I no longer need to use the supplied external drive. This was mainly for convenience, and as I have a dedicated laptop, disk space was not an issue. It makes a huge difference in the number of cables that you need to worry about during a diagnosis session.
Finally, my Chinese SDS is a very useful tool for a MB enthusiast, but be warned it is very temperamental. Now that I have reached a stable configuration I no longer fiddle with the installation settings (especially the inbuilt SDS tools such as SDnetAssist etc.) which are available via the Virtual Machine Start, All Programs, Service, etc.) as these seem to create errors, which in my case usually require a full reinstall. I keep a dedicated 150Gb hard drive with a cloned backup of the supplied SDS HDD for this purpose.
Regards,
ricebubbles
Key search words:
Chinese MB STAR Compact3 C3 Diagnostic Diagnosis Assistance System SDS DAS PCMCIA Cardbus Adapter Card OX16CF950 RS232 COM2 serial port settings MUX application software installation guide guidance tips how to fix understand how I fixed Xentry Diagnostics Workshop Information System WIS SDS What is it SDS Instructions For Connecting and Using SDS Software Installation Instructions partition laptop HDD clone external HDD drive
Discussion Starter #2
Help Needed to Understand my Chinese Star Diagnosis System SDS Compact C3
As I explained in my previous post, I still have several issues in understanding my Chinese Star Diagnosis System SDS Compact3 C3. Any help will be much appreciated.
The documents referred to were attached in my previous post.
Issue A: MUX Icon Remains Unlocked.
My SDS seems to work fine now that it is installed on the laptop internal HDD, except for one small detail. The MUX icon on the Virtual Machine Desktop used to change from unlocked to locked once the car was connected and communicating properly. See Figures 8 and 9 in Document 2 SDS Instructions For Connecting and Using. Now the icon doesn’t change from unlocked for some reason, but the MUX is definitely connected and working. I have tried all the obvious connection settings but nothing affects it. It is a minor detail and I can live with it, however if any one has any idea how to fix it, it would be much appreciated.
Issue B: How to delete/remove an unused MUX Icon.
When the Virtual Machine Desktop starts it shows the Desk Band Group of icons in the bottom right Toolbar. These show the connection status of the SDS to the Internet and to the MUX. The initial icon in my Desk Band is a legacy from when I first got my SDS going. It shows the MUX as ‘D6’. MUX ‘D6’ also appears in SDConnect Toolkit as well. See Figure 5 in Document 2 SDS Instructions For Connecting and Using. After recovering from my inoperative SDS (see previous post), now when I connect my MUX to the laptop, the icon changes to a ‘D’ icon with an unlocked padlock. See Figure 90 in Document 2 SDS Instructions For Connecting and Using. My issue is; how can I delete the original ‘D6’ entry?
Issue C: Purpose of a couple of applications in Virtual Machine Folder ‘mb activate tools’.
My SDS came with a folder called ‘mb activate tools’, which obviously contains several tools, applications and patches for fixing the various problems which occur with these Chinese SDS’s. Some of the applications are apparent as to what they are for, but some are not. I need some help in understanding the purpose of a couple of them.
“C4_To_C3” Seems like it has something to do with converting a Compact4 (C4) SDS to a Compact3 (C3) SDS. Why would you want to do this? As I understand it a Compact4 (C4) SDS has the same software as C3 but has better anti electromagnetic interference properties and smaller hardware and is required when using a SDConnect (wireless MUX).
“Convert C3_to_C4_SD_Connect” As I understand it, SDConnect is the name given to the wireless version of a MUX which came after the earlier RS232 cable connected MUXes. Therefore it seems that this application is to convert a Compact3 (C3) SDS to a Compact4 (C4) SDS, to suit a wireless MUX, if that was what was supplied.
Folder ‘mb activate tools’ contains a file ‘wrar393sc.exe’. What is this application used for?
Issue D: Also a general question. In the brief instructions that have been provided with one of the patches, it states to “copy the application to the affected laptop”. Does this mean to run the exe file from the Virtual Machine Desktop/environment or from the Host Laptop Desktop/environment?
TIA,
ricebubbles
2002 s500, 2004 S500 fourmatic
Ricebubbles:
I'll bet that wrar393sc.exe is a self extracting file to install
WinRAR version 3.93
an older version of the winrar archiving system.
2006 E55 AMG
RiceBubbles,
Thanks for all the info...I have an "for education" setup also and was wondering what to do with all these cable etc. I have some experience with serial RS232/RS485 comms in general and I'll try to share what I come up with.
I got my setup yesterday and so I far have the software installed and running. I have yet to connect the multiplexer to the car. I'm going to give my trusty USB-RS232 adapter a try first (its about 6 yrs old) and has worked for a lot of data acquisition projects in the past. I'm still ordering the PCMCIA card today and an industrial RS232/485 USB adapter to test.
Great post, really learned a lot from it. I have on issue unrelated to this, I'm mostly interested in WIS and EPC and I found and downloaded some version from 01/2012 Looks like it isn't the Standalone version but the Wisnet Ewanet which you briefly mention in one of your .pdfs. Unfortunately i don't know how to install it(need StartKey) and i've been googling for hours without any luck, like it's impossible and I'm left wondering why would somebody upload software which is useless. Since u seem to know more than all the resources i managed to find googling for past 5 hours i guess u are my last hope :)
Hi LethalIndustry,
Unfortunately I don't think I can help. All I know on this topic is in my attached pdfs a few posts back.
Regards,
ricebubbless
I recently bought one of these C3 clones and it came with ZERO documentation, so I was quite pleased to find the information which you have provided. I do have one question. Does everything have to run through the Virtual Machine program? I have yet to locate that program on my machine. I have copied the 80 Gb hard drive which was supplied to a 250 GB drive which had XP pro already installed. Thanks. Bill
Hi Bill,
The Chinese Star definitely needs to run in the virtual environment, unless you have an IBM T30 laptop. Apparently the VMWare progamme emulates a T30 Desktop.
Re your copy on the larger drive. Just keep a watch that the drive letter designations make sense and are recognised. You will notice in my pdf that I carefully arranged the copy on the internal hard drive to be the same letter designation as when it was used from the external HDD.
Brian
Thanks for the reply, Brian. My supplier supplied the HDD for either the IBM T30 or the Dell D630. I bought one of the Dell D630s to run the program, so maybe I don't need the Virtual Machine. I have been tracking the drive letter designations. In the package with the HDD was a flash drive. My computer recognized this because I got a message telling me that drivers had been installed. But, when I go to "My Computer," this drive does not show up. My supplier told me that this was a "key" for the program. Has anyone else gotten something like this? I had hoped that it contained some documentation. Anyone have an idea of what this does? Thanks. Bill
Zotye Auto 1.5T T600 2016
Learn to use the forum search function;
https://www.google.com/url?q=http://www.benzworld.org/forums/sale-wanted-trade-giveaway/1650795-startkey-xentry-das-epc-also-most.html&sa=U&ei=m-swUOIVgf6YBfWUgYgF&ved=0CAYQFjAA&client=internal-uds-cse&usg=AFQjCNEQ2tJNWE1TsvEv6Y2qksu4keOguw
SLK55, E63
If you bought the hard drive for the Dell or IBM directly, you do not need the virtual machine (and, in fact, you don't have one on the drive).
The key on the flash drive should be used in "import key" in the SDSUtilities program. It probably contains a text file.
As far as other keys, there are various keygens on the network to make it do whatever you like. The damn things are fussy, though, and take a lot of reading. Some of the keys use a hardware "fingerprint" that is a hash of the drive ID, Mac address, and CPU serial number. Others use only the MAC address. DAS, in particular, uses a fingerprint key on the first install, and then uses the LAN ID (MAC).
Some of the disks are supplied with "MB Activation Tools" or something like that. It's a collection of what's on the net.
Fair warning: Many of these disks are seriously virus infected. Do not mix these disks with your regular PC or you will be in a world of hurt until you are sure. One virus, in particular, that is often "supplied" replicates itself faster than the anti-virus software can get rid of it. I had to go to an off-line program to get it off my disk.
as explained above, it is a very involved installation if you are looking to run it natively on your system.
It was originally designed to be the only thing running on the laptop. It was also designed to block anything else from installing on the laptop as well.
This being said, it can be installed on a laptop other than a VM and dedicated machine if you wish. The install DVD are not on the harddrive given with the china clone and you can't just simply copy over the program. They are keyed to your hardware and moving the files will just create a key error.
The other big issue of the software on a computer you use every day is that its timed. They will only work for so long. MB issues new "updates" every few months (3 i believe) and the old software will timeout. You will need to keep your calendar date rolled back to within a month or two of your version date. If you do happen to get it installed and want to keep updating with MB as the updates come out, good luck. Every install of an update gets harder and harder to crack.
Im still on 09/2011 on my version. I am running it on a Mac and keep it in a VM. Just open it when I need to do some work.
Hi
Im trying to set up my MB star c3.
I have followed an instruction that was on my VM desktop.
When i come to the point where i enter a new start key in star utilities it al seems to go ok, and i get the message save sucsessfully! But when i close the window and opens it agian the old key is still there! Anyone knows why this happens!! :confused:
'02' S500 (W220)
Hi
Did you generate a new start key in Xentry Developer? If so, you need to make sure the start and expiration dates are correct then generate a new key. Once the new key is generated, you need to copy new key and paste the new key to the Start Key Manager "Start Key" and save. Also, you should create key in DAS not Xentry Diagnostics.
'03 Mercedes S320cdi, '01 Mercedes S430
I just recently bought one C3 and seen the problems others facing decided to upgrade it to a Dell lap top.
So will see what happens but realised that its not an easy installation and as I see also not an easy ride to use it...
Most probably will have some sleepless nights... :-(
'02' S500 (W220)
Actually the installation is not hard. Did you receive a Hard Drive with your C3 containing the program? If so, you need to remove the HD from the Dell and install the HD that came with your C3 kit. That's really not that hard either. After that, turn it on and begin the process of programming the system for usage.
Cars: 2003 W220.184 (S500L 4matic)
@all
Those who have a reliable solution - what and where did you purchased C3? PM is also desired.
@all
Most of the Chinese suppliers are located in Shenzhen China, a city just over the low wu border with Hong Kong.
2009 E350 4M Avant Garde, My Mistress 2002 S600, Wife 2014 C300 4M Avant Garde with AMG
Don't buy via fleabay, use alibaba.com ( they hold the money in escrow until you receive the merchandise and are satisfied.
Huge selection of DAS systems and HDs
1 - 20 of 53 Posts
