NNot too bad...
For the rear, raise the car up until the wheels are off the ground (use plenty of jack stands) and you can get underneath and put a jack underneath the arm under the spring and remove the bolt that holds the arm in place (towards the pumpkin) and then release the jack and let the spring drop out, reverse to get it back in. Jack the front up and the fronts are mcphersons so you remove the whole assembly, bring it to a shop and have them use their air tools and spring compressor to replace the spring and then put it back in your car. I would not advice trying to disassemble the mcpherson strut spring yourself or you will hurt yourself.<br> <br> Then of course there's the easy way, bring springs and car to dealer and get loaner, come back at the end of the day and drive away. My dealer wanted $270 for the whole job. Keep in mind that it requires a serious alignment job that will probably cost you over $100 anyway.
