Have searched forum cant find, how does the radiator expansion tank work the large hose coming out the bottom of the expansion tank where does it go cant see where its hooks to the radiator
On the 560's, that hose connect to the bottom of the radiator, next to where the lower radiator hose connects. There's a smaller nipple on the radiator which the expansion hose fits onto. Then the smaller hose on the top goes into the top of the radiator, and finally, the small hose off the cap goes to another tank inside the passenger fender.
The pdf doesn't show the second tank under the pass side fender well:
as the descution on this is over, ill jack this thread & use the diagram provided to see if someone can help me in figuring out where i would install a circulating heater in my coolant line, or will it just not work in a 560 sec. thanks in advance.
