1 - 8 of 8 Posts
Does anyone know how to remove the front and rear door panels and the rear deck to replace the speakers in a 96 E320. I briefly looked around and tugged on stuff today but couldn't seem to figure it out (I was mostly too afraid to break anything). Also, I have the Bose system--where is the factory amp? Are the speakers in the rear deck subs or just regular woofers? Any info would be greatly appreciated.
Discussion Starter · #5 ·
Re: Dana, Which part? You just want remove the panels. Thought diagram is enough..
The diagrams are great and they helped me remove the panels--thanks! But it would be nice to be able to read what the pin assignments are, etc. Do you know what they are?
Discussion Starter · #6 ·
Pin assignments.
According to what it says:<br>
<br>
1 Pink Rear Lt positive<br>
2 Green Front Lt positive<br>
3 Black Front Rt positive<br>
4 White Rear Rt positive<br>
5 Brown W/ Pink stripe Rear Lt negative<br>
6 Brown W/ Green stripe Front Lt negative<br>
7 Brown W/ Black stripe Front Rt negative<br>
8 Brown W/ White stripe Rear Rt negative<br>
<br>
9 Black W/ Yellow stripe Accessory(12v on ignition)<br>
10 Blue W/ White stripe Antenna remort(amp turn on lead)<br>
11 not in use<br>
12 Green W/ Black stripe Speed sensor signal<br>
13 Brown Ground<br>
14 Blue W/ Gray Illumination<br>
15 Red W/ White 12v constant <br>
16 not in use<br>
<br>
Want to change the HU?<br>
Hope this will help.<br>
Dana, if you want more, email me.<br>
<br>
<br>
Discussion Starter · #7 ·
How about how to remove the rear deck?
Thanks for all your answers. They really help. Do you know how to remove the rear deck in a 96 E320? My rear deck seems to be a little different from the diagram in your link.
1 - 8 of 8 Posts
