'76 1300L,HE351CW,H15P Winches,Konis,Hydraulics,All Gears,10mm Plungers,Aftercooler,Lots of Littles
I have a couple with bad bulbs in them, but I cannot seem to get them apart. Anyone done this?
Thanks.
Charles
U1450L DOKA
I've done it. The square push button pulls out, and the bulb is held in another
plastic sleeve that fits into the main body. I just left the shop where I have a loose switch that I can take apart and photograph- but it will be Tuesday.
I can't remember if you twist the button to get it to release from the switch body, or if it is a straight pull. Not very helpful, I realize, but it has been a while.
You could try both if you don't want to wait until Tuesday...I think I'd try the straight pull first.I don't see a twist component built into the button portion. It seems like it won't come, then it does...
Then you slide the bulb housing out and pop the bulb out....
Also, the ICON lens just pops out with a small screw driver,but you can't load the bulb through that hole.
Thanks, Trucktor. I will give it a pull.
