2008 R350 | E46 M3
I don't see level markers (high/low) when I remove the cap. Should the fluid be filled to the top of the reservoir? I have a 2006 R350. Can I top off with just distilled water, or should I top off with 50/50 water/coolant?
Thanks in advance for your assistance!
06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
You should top off with 50/50.
I think you are supose to put the level at the little tab that you will see when you take off the cap, directly down. That is what I was told.
2006 Alpine Rain R500
Some coolant loss will be noticeable due to evaporation. It is suggested to topp off with water instead of coolant. If there is a large amount that is needed to topp off, might want to get the cooling checked out due to possible leakage. The coolant is G05-you can find it also at auto parts store or pay a little bit more and get it from the dealer, but the same stuff.
Zotye Auto 1.5T T600 2016
Correct, inside the header tank is a small plastic extrusion and the top of this is the level.
For the coolant properties, are there additives to prevent cavitation?
