it appears my idle is low (500 rpm in D), and my engine shakes almost violently, so I am almost always forced to go to N as soon as I stop as it seems to smoothen out the idle a bit .. (I have had all engine and tranny mounts checked out at the shop and I was told the mounts are fine.)
I took off the air cleaner assembly to access the accelerator rods, where I turned a knob that seemed to increase the idle a bit by pulling the acc cable, but there is a swicth that clicks when the gas pedal is released and if I play with the adjustment on the kbob, that switch goes into open position.
so is there a screw I can turn like on other cars where the idle speed goes up a bit without fiddling with the accelerator rods?
what is your idle when tranny is in D and you are stopped?
