Transmission oil
There is a 5mm alen key in the transmission sump to drain it. When you have drained it, undo the six 13mm bolts holding the sump on, and you will see the filter, it is held on with three philips screws. (It's a messy job).
Don't know what the recommended intervals are in ths US, but in the UK it's every 36k[
