Hi all,
Just got this 190 Diesel a couple of months ago and is now having trouble shifting. It would appear to most likely be the shifter linkage bushings on my standard 5 speed transmission.
Can anyone help describe how to do this? Is there a thread with instructions on how to replace those? I understand some are accessed under the car and the ones inside the shifter would be accessed from within the car. But that's all I know, I could really use some instructions, at least in terms of how to get started and exactly how many bushings there are and where.
I have the kind of transmission where 5th and reverse are on the same side (right side) by the way.
Any help of any kind is VERY much appreciated, I can't afford to take this thing to the stealer and I want to take this on, but not blindly!
Dan
'87--190E 2.3-16v(being rebuilt), '99--C230 Kompressor
go to 190rev.net a person on there makes and sells delrin shifter bushings...kinda like really hard teflon...much better then factory rubber....
shifter bushings can be a pain but easy enough...jack up the front end, disconnect rods from shifter...pull shifter out (4x 10mm)...replace...reinstall...reconnect...disconnect from trans...replace and reinstall. all the rods are held on with spring clips. best to change them out as well if your doing the bushings...they are less then $1 each. may also need a pain of vise grip to get the bushing into the rod... search on here there are a few pics floating around about the breakdown to the shifters
Thanks, unfortunately it looks like it is also the ones inside the shifter.
Got replacements coming in the mail.
How do I get started on that ? Does the boot just pull off and I do everything from inside the car?
1984, 201.122, OM601.921, G717.410
There is an older 2010 post describing how to remove the center piece between the seats. Then you remove the shift lever mechanism.
