1988 Mercedes 500 sec
I need to remove the aluminium intercooler pipe that goes from the turbo and then i assume to the intercooler, i removed the torx head screw by the rad and the torx head bolt holding it at the top but it would not move, what other bolts do i need to remove please
Also need to remove the engine undertray as i dropped a torx bit down i assume its sitting on the under tray
Outstanding Contributor W221 Moderator
2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
Hi @Benz 1 ! A lot will depend on which engine you have as there are several with turbos in the W221 chassis. What is the model/year of your Benz? (assuming it's not the '88 W126 in your profile. ;) )
