How do I remove the air cleaner from my 190E 2.6?
866 Views 4 Replies 1 Participant Last post by  Guest (MBNZ)
I removed the two nuts on the passanger side of the air cleaner and loosened the one on the drivers side. I tried to pull the air cleaner off and it would not release. Did I miss a screw or do I need to pull harder?<br> <br> thanks,<br> Cliff<br> <br> 1992 190E 2.6<br> Color Gold<br> interior Tan
Manny,<br> I removed all you suggested and tried to shake and pull still no luck. Do I need to pull harder. I am not able to release the rubber rings between the lower part of the air cleaner and the throttle body.<br> <br> Cliff
