1999 SL500
I found my power steering fluid low this morning. From the top I cant see any leaks. Will I be able to see it if I put the car on a lift? Or whats the best way to get in there and check?
Is there a common leak for the PS pump?
Frank
1999 E430; 2005 ML500
The first first place to look is behind the fluid reservoir; these cars always develop leaks there. Next place is to follow the hoses and check their junctions. The last place is at the tie rod boots coming out of the rack and at the pinion/spool valve.
