1 - 1 of 1 Posts
I'm referring to the one under the 'brush' in the trunk (S69/9 or called Limit switch of Vario roof open). In this post of Bazzle (link 21) http://www.benzworld.org/forums/r170-slk-class/1292734-roof-switch-repair-rear-3.html he refers to a 'square plastic flap' and a 'lidded flap' that holds it in place. I think that I found the 'lidded' flap at the bottom of the switch. The switch will move slightly if I release the flap at the bottom, but will not come out. Where is the other flap that holds it in place?
I'm trying to remove it through the opening next to the hydraulic pump since I don't want to remove the complete trunk liner just to get to this switch, so I cannot really see the switch properly.
1 - 1 of 1 Posts
