21 - 27 of 27 Posts
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
@cmitch: Agreed, and you might as well use a new part instead of used. Reason: you're in there anyway, and US $150 every 15 to 20 years is not a lot of money, given the type of automobile we're talking about here. Might as well do it once and be done with it.
@wallyp: Fuses can also melt if an electronic component--say, a transistor or capacitor--goes bad in the wrong way, causing a short circuit and thus too much current flow.
@Dave2302 is correct; I was saying exactly that. M-B indeed had them listed incorrectly at the time. I had let them know, and apparently they've now fixed it (this is a Very Good Thing).
Here's what I mean.
In the first image, you see the diagram for the "Blower Motor and Fan" section. Note that this is the Front section, not the rear. Item #1 on the diagram clearly lists AC and Heater Assembly (FRONT). You will also see items #22 and #24. Item #22 is for the blower motor and fan itself. Item #24 is the regulator.
Let's continue with image #2. What part # is the regulator? 2208210951. It didn't say that before; rather, it had said, "220-820-92-10". Note the dashes in the incorrect part #. That format matches every other part # in the list, so this was a recent change, probably due to both alerting them and the discussion in this thread. That's good news.
We see this further in image #3. No dashes in the part number, which is unlike all the others. This was clearly a copy 'n' paste operation, but I don't mind, since now, as Ray Charles used to say, they've got the right one, baby! :grin
Now they have a correct part #. The form factor for 2208210951 looks just like 2308210251 and is very likely the W220-specific part # for the same part (the part # on my old one starts with "230", which would normally mean the R230, or the SL convertible).
Just now checked a couple more online M-B dealers (e. g. M-B of Wappinger Falls). They have this updated part #, too (2208210951 - no dashes), so it looks like someone alerted MBUSA.
So, now apparently things are set right, and that's good.
2003 S500
The fuse holders and fuse bodies for the standard-sized plastic fuses are identical for up to 30 Amps in normal operation - the only difference is the small fusible wire. If you create a "crowbar short" (a direct short circuit from power to ground) in a fuse-protected circuit, the fuse will blow instantly - it will never melt the plastic body or the fuse holder.
I don't believe that you can do anything to melt a fuse by overloading the circuit.
Ah, you meant the plastic body that holds the fuse, not the fuse itself. In that case, I'd generally agree with you.
Hypothetically speaking, if there were a continuous heavy load on a circuit (say a 29.5 amp load through a 30 amp fuse), couldn't the fusible section in the middle of the fuse heat up without blowing? Not saying this scenario is a common occurrence, but it could happen and melt part of the plastic carrier.
21 - 27 of 27 Posts
