1 - 9 of 9 Posts
c320
Discussion Starter #2
shoudl add this is the blinking indicator which folds on each front door. Had a look and cannot see how you take this apart?? really dont want to take it to a dealer!
2002 C230k
http://www.mbklasse.com/forums/editpost.php?s=&action=editpost&postid=31544 will tell you how to get to the bulbs.
c320
excellent!
all done but no bulb at fault.. a wire was torn part, i think this happened the other day in a carpark when i fodled the mirrors and instantly the l mirror fault was displayed.
many thanks!!
mobe
SLK350,C230Komp
I know this is silly but I can't get it apart.
Can't even see what to remove ......
How did you get yours off?
Do you push the entire mirror toward the windows, and look for a screw or some sort?
do you need to remove the whole mirror in order to get the the blinker?
I tried but it is too hard, don't really want to break anything or take it to the dealer.
c320
what you need to do is fold the mirror
once folded if you remove the black plastic cover - little fiddly
once removed you will see a small clip about an inch wide
use a flatend screwdriver and push left and you will feel this move
make sure the glass is central and you will feel this let go and you should then slde the plastic case off.
did mine! but some idiot drove past and hit my wing mirror today.. smashed the indicator clear lens... not happy[:(!]
1 - 9 of 9 Posts
