We all had to find out how to do something once! Good info - so for W164's there is no drain plug and we need a vacuum system! Would be grateful if someone could link to a suitable toolIt's one of those questions that if you have to ask you can't do it.
Why would he need that?MOST IMPORTANTLY: Mercedes service DVD for W163.
A vacuum pump and adjustable rubber filter strap wrench can be found at any auto supply store for the mid 50 buck range. There is a drain plug but it is hidden under engine cover but it makes for a much bigger job. Filters you can get online or from a dealer. Make sure you use the right spec oil. also take out the oil filter first to allow it to drain and you can refill using oil filter hole if you want.
With all due resepect, if someone asks a question, answer it, or skip it and go on and read another post.It's one of those questions that if you have to ask you can't do it.
Depending on where you live etc you can have Amsoil Euro car formula delivered right to your door or pick it up at the local ditributor. It meets or exceed all the specs. Check the amsoil website for info http://www.amsoil.com/storefront/afl.aspxI bought this MB oil from the dealer. $7.43 per Quart. Mobil 1 ESP formula M 5W-40 MB-Approval 229.51
Do you know where I can buy a similar oil?
Thanks.
Your local NAPA store has Valvoline Syntech that meets MB spec 229.51 and is approved by MB. LAst time I checked AMSOIL was not MB approved.I bought this MB oil from the dealer. $7.43 per Quart. Mobil 1 ESP formula M 5W-40 MB-Approval 229.51
Thanks.
Perhaps you should check again before you post things like that..amsoil has had MB spec oil for a long time http://www.amsoil.com/storefront/afl.aspxYour local NAPA store has Valvoline Syntech that meets MB spec 229.51 and is approved by MB. LAst time I checked AMSOIL was not MB approved.
Home Depot will have the hose you need.I have used the MityVac pump up model and it works very well. However, the suction tube is too short to be able to set the MityVac on the floor and get the tube inserted fully so I have to prop the Vac up a little. Not serious but a longer tube would be nice. Jim W.
Mine came with 2 diameters of plastic tube and a crossover rubber connector to be able to make them fit together so I do it that way to have enough length. Otherwise mine is too short as well but works fine doing it that wayI have used the MityVac pump up model and it works very well. However, the suction tube is too short to be able to set the MityVac on the floor and get the tube inserted fully so I have to prop the Vac up a little. Not serious but a longer tube would be nice.
Jim W.
