1 - 9 of 9 Posts
'95 E200 MasterPiece
Hi all,
Is there a way to change the stock automatic gear shift knob? If possible how do i do it?
230E 1992
I have a friend who just got a new shift knob for his 1992 230E..He told me that the original shift knob is molded into the end of the shifter stick and there is somewhat like a round ball at the end. he cut the roundball just to fit the new knob...
sap555 - 2/9/2005 12:05 PM
Darn this is tricky then.... I'm afraid I won't be going to the extent..
Why doesn't anybody do a search[8)][:)]
All you have to do is remove the wood console then remove the plastic covering, move the rubber boot up and unscrew the bolt at the bottom of the shaft.
You can then replace the shift knob with something similar or you can buy an adapter shaft which will allow you to put any newer mercedes shift knob on the shaft.
hmmm... i see..
I think this adapter shaft + knob thing will probably set me back around US$100+ at least..
Bummer. Ok so take out the ony you have and have it cut just below the current knob.
Just an idea....
1990 W124 300TE-24 3.4 AMG, 1991 W126 300SEL
look at this
http://suzutaka.fc2web.com/lever/0501.html
want translation just go to
http://babel.altavista.com/
I got mine done by MB Workshop for $180 sdg ...that is inclusive of the gearknob from w210 burr walnut and black leather.
My next project is replacing my w124 steering wheel to a w210 one... please see this
http://www.geocities.jp/mejironosuzuki/2161.html
W210 steering is 10mm smaller than the w124...nice [:D]
RafMAR - 2/10/2005 4:24 AM
Cool RafMAR!
When u are done with the steering wheel project, kindly post a pic or two here on ur new steering and knob!
Cheers mate!
1 - 9 of 9 Posts
