Hi Everyone
I have a 2006 Mercedes E350. The car operates normally except in hot weather! Whenever the temps climb beyond 70 degrees, I start hearing a thunking sound in the front of the vehicle as I'm slowing down or stopping. This also occures at slow speeds such as starting from a stop sign and when I turn my steering wheel from side to side. But it only happens in hot weather.
I have taken the car to 4 dealers and they can't find the problem. They can hear the sound but can't diagnose it. They have replaced the rack and pinion, the struts and the bushings, but it's still making the sound. Do you think they replaced a defective rack and pinion with another defective part?
Thanks!
2006 CLK 350
:thumbsup: Switch the tire to the rear... if it still thumps from the front, then it's not the tire! .. maybe temperature sensitive shock or brake pad/rotor?
Good Luck
