My dash lights render the HVAC knobs uncomfortably hot shortly after the headlights are switched on. Anyone else experience this?
Kevin
79 240D
2008 PT, 1998 neon--1965 VW 1200
i have the same car and my knobs arent hot.
i hate that i dont have a scientific sounding answer for you!
the only thing i can think of is that it is one of two things--
someone replaced the bulbs with the wrong ones or there is too much voltage running through it and its going to melt one day[:p]
RE: hot climate controls more info
The gauge lights are pretty weak, only really helpful when the rheostat is turned up almost fully. If I turn it all the way the dash lights go out. The HVAC lights don't seem excessively bright so I didn't think the rheostat was the problem but I'm beginning to wonder now....
Kevin
79 240D
W-1-2-3 Go!
The wiring might be corroded, leading to added resistance and more heat, even if the bulbs are dim. Actually, I think it makes sense that they are dim and there is corrosion. If there wasn't any corrosion they'd probably be bright but have less resistance and would not be hot.
