1 - 1 of 1 Posts
Hi all, since two weeks ago, when i start the ac, my w124 1990 blows very hot air by both sides (Passenger and driver). The center blowers is fine, very cold air.
I fix this problem, making maintenance to the duo valves, and it works fine for some days.
The problem is that when i dismount the duo valves again to clean it for 2nd time, both valves was broken, ill try to bond it, but this doesn´t work, still blowing hot air.
Having in count that I never use the climate control, (i just need cold air) my question is.
May I cut or seal the pass of hot water to the cabin, without causing damage to the motor, and which is the best and cheepest way to do this "calefaction vasectomy".
Advanced thanks all, for your help.
1 - 1 of 1 Posts
