1 - 8 of 8 Posts
300e - 24
Have recently bought a 300e -24, 1992, 180k on the odometer and it has some strange problems
1) It is really hard to start when cold ( Have checked the OVP tested fine ) :(
2) Burning around a liter of oil every 1000 km
3) The oil pressure gauge is showing less than 1 at Idle
4) The car shakes like a joyride while idling although the idle is constant at 700 rpm
The car is great in driving, the question is should I go for the rings or should get the pistons changed as well ( according to the mechanic ).:confused:
Have checked a lot of posts and they have been really helpful and informative, great job u guys.
300e - 24
Well i will have the mounting checked too, untill now i have had the alternator changed and battery, plugs replaced , one more thing is that i have read a lot about this Idle control valve even saw the picture in the posts but my car is bit different from the one shown in the pic.
Mercedes E200 black. Mercedes 300ce - sold.
#2 is normal
#3 it should be no lower than 1.5
1990 560 SEL & 1995 E300D
Valve seals! Your oil consumption is likely due to this given the mileage.
300e - 24
Discussion Starter · #7 ·
Well i guess that i should get a comprehensive checkup done.... but the issue is that u know how mechanics want to swindle .... and i dont want go for the wrong things... i have already done the electrical basics ... but like i read in a post.... if its not broken dont fix it.. which is what i want to do.
Thanks for the comments will get the tests done.
1 - 8 of 8 Posts
