Hi all-
The hose between the block and the water pump sprung a leak. The hose is only about 4 inches long but the problem is the gap between the 2 pipes (1 the block and the other water pump) is less then a quarter inch. The thickness of the new hose will not pass through. I really don't want to remove a perfectly working water pump to replace the hose. Help!
Its a w126 1990 300se
