I just bought my son a 96 C280, it has a few problems, the horn does not work, I do not have 12VDC at the horn, and I do not have an owners manual which fuse is for the horn? I should be able to check continunity of the steering wheel switch from one side of the fuse to ground correct?
Thanks,
TimE.
The main fuse box is under the hood next to the brake booster - fuse explanation should be in card inside
Hope it is just a fuse
There are also fuses in the module box on RH side under hood and also in trunk near battery
