MB 220D/8
Still messing with the 71 220d discovered that the horns are not going - I have power to the horn and assuming the circuit is made when you press the lever on the steering wheel. Had assistant press horn and showed power so
I just expect that they are dead due to old age/dirt etc.
Any suggestions of suitable replacement? I have seen high low horns from napa which look ok. Can I use a single high/low combined horn and just use one of the connections or does it need to be wired in series to make it work?
Lee
1994 S500 LWB, 1970 220D, 1994 E320, 1992 JAGUAR XJ6
i dont see why you couldnt buy one from a 123 chassis on ebay and have it work..i have a 73 with the same issue but then again the horn is the least of my problems lol
