Me again. This is the last repair to get this car road-legal.
Found the horn on the prints and it shows K39 for the Y.M.1994, but the Relay & Module location chart doesn't show where K39 is located.
Anyone have some insight about the Fanfare Horns?
Dean.
Dean.
Searching another website revealed answer for a 95 E320 !
"The EPC shows the "trumpet horn" relay as being in the relay bracket of the fuse box - part number 001 542 99 19 ???
OR ELSE
it may be behind the instrument on a bracket in front of the K38 starter lock-out relay."
Thanks StormTigers,
Mine is apparently a limbo vehicle in between two YMs. The wires from the horns trail off along the passenger side and disappear below the battery, bound for the steering wheel. Never did make an actual repair.
Installed a new button at the base of the steering wheel and built a new relay circuit for the horns. Works good.
Someday I will have things apart and fix it back correctly.
Thanks for the help anyway !!
