1 - 12 of 12 Posts
BOOsted W126
i dont know why, i checked the hinges and everything seems ok. the left part of my hood keeps popping up, any ideas, this is dangerous when im on the highway
500 SE EURO!
close it hard, then try to open it by pulling up... i use to have that problem...but after 'adjusting ' the cable to the hood -- everything seemed okay till today...
1988 560SEC, 1987 420SEL, 1986 500SE
I'm not sure that I'm understanding the problem...the hinges (and I assume lock) are OK - then what exactly is popping up and how?
1983 300 SD; 2000 E320
I have trouble getting one side of my hood to latch. I am going to try shimming down the lock on the hood.
BOOsted W126
Discussion Starter · #5 ·
when i shut the hood hard hard it locks. after a while of driving the left side of the hood pops open but the right stays closed
I'd also check my trunk seal...my lid did that after I replaced mine and put it in wrong.
PS: Ahhh, I totally spaced...was obviously thinking trunk all the way. Never mind then...and yeah, I would side with the catching mechanism opinion. Sometimes it happens to my hood, then I just open it and make sure to drop it straight (I am SUCH a mechanic!!) and that seems to take care of it.
1989 560SEL
neil.b said:
Try cleaning and re greasing the catch mechs.
i second this. i had a problem with the left side of my hood latch until i sprayed WD-40 into the latches. since then, it's been fine.
can someone explain the difference between what cleaning and greasing the catch mechanisms does and adjusting the cable.
2005 SLK350, 91 300SL with Pano Top, 04 S500, 2015 Tesla Model S
I have the same problem. Generally, you do not have to adjust the cable. The catch mechanism has a metal plate which is pulled back by a spring when the opening cable is released. When dirt or corrosion gets between this plate and the static metal mount of the catch, it binds and does not return all the way causing the problem of the hood popping up. Spraying some kind of cleaner into the area and working the plate back and forth should free it up. You can see this plate when looking at the catch mechanism below the cross beam.
BOOsted W126
Discussion Starter · #11 ·
before my hood started popping up i was cleaning my engine and decided to spray some wd40, thats when it started popping up. i will get some engin degreaser and try to clean it out
1991 560 SEC, 1989 560SEL, 1999 C230, 2009 E350 Sport 4m, 2011 E350 Cabriolet
Clean the hood latches
Try cleaning the hood latches and cable release first with WD-40. Then used White lithium spray grease after. This should resolve the hood latch issue.
1 - 12 of 12 Posts
