Green '02 E320 Wagon
My 2002 E320 4Matic wagon has slits (cowl?) in the hood near the windshield to allow air in (I'm guessing to the passenger cabin). Under the hood is a large air dam which channels the air where it should go. I removed that and cleaned off the dust.
Under that large air dam, bolted to the hood, is the grated screen under the hood slits. It's a filter to prevent large objects from entering the large dam. The right half (left in the picture) was covered by a plastic part which I could see was retaining debris. I used a screw driver to pry around its edges and it easily came off.
It's not supposed to come off. That plastic part was heat-welded in place. Its plastic was melted all around its edge, then it was pressed permanently to the screen.
The plastic was labeled as "PP" which I trust means polypropylene. I will try to find "plastic weld" compatible with PP to affix this piece back into place. Failing that, I'll get one from a junkyard (with its own history of embedded debris).
Is there any way to properly remove and clean this area? Or clean it without removal? I'm shocked that Mercedes made a component which can't be serviced.
Compressed air.
1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Compressed air.
^^^^^^ When I got my 2003 W210 Wagon, I took it of the hood and blasted it with compressed air followed with a strong jet of water. Took some time, but it worked.
I might try my pressure washer next time.
