2002 S500, 1993 Nissan 300zx
My S500 did not come with manuals, and I sold my CL500, so I can not remember how to program the homelink to open my garage door.
Can someone do a quick writeup and post it here?
Thanks a ton,
Randy
2004 S500 4Matic, 2006 S350
You can log on to mbusa.com and go to the service section and download an owners manual if you car is a 2000 or newer. Here is the instructions I just copied off of the manual.
Programming or reprogramming the in-
tegrated remote control
Step 1:
? Switch on ignition.
Step 2:
? If you have previously programmed an
integrated signal transmitter button
and wish to retain its programming,
proceed to step3. Otherwise, press
and hold the two outer signal transmit-
ter buttons2 and 4 and release
them only when the indicator lamp be-
gins to flash after approximately
20seconds (do not hold the button for
longer than 30seconds). This proce-
dure erases any previous settings for
all three channels and initializes the
memory. If you later wish to program a
second and/or third hand-held trans-
mitter to the remaining two signal
transmitter buttons, do not repeat this
step and begin directly with step3.Step 3:
? Hold the end of the hand-held remote
control transmitter6 of the device
you wish to train approximately2 to
5in (5cm to 12cm) away from the sur-
face of the integrated remote control
located on the interior rear view mirror,
keeping the indicator lamp1 in view.
Step 4:
? Using both hands, simultaneously
press the hand-held transmitter
button5 and the desired integrated
signal transmitter button (2, 3
or4). Do not release the buttons until
completing step 5.
The indicator lamp1 on the integrat-
ed remote control will flash, first slowly
and then rapidly.
Step 5:
? When the indicator lamp 1 flashes
rapidly, release both buttons.
Step 6:
? Press and hold the just-trained inte-
grated signal transmitter button and
observe the indicator lamp1.
If the indicator lamp1 stays on con-
stantly, programming is complete and
your device should activate when the
integrated signal transmitter button is
pressed and released.
Step 7:
? To program the remaining two buttons,
repeat the steps above starting with
step 3.
Rolling code programming
To train a garage door opener (or other roll-
ing code devices) with the rolling code fea-
ture, follow these instructions after
completing the “Programming” portion
(steps 1 through 6) of this text. (Asecond
person may make the following training
procedures quicker and easier.)
Step 8:
? Locate “training” button on the garage
door opener motor head unit.
Exact location and color of the button
may vary by garage door opener brand.
Depending on manufacturer, the “train-
ing” button may also be referred to as
“learn” or “smart” button. If there is dif-
ficulty locating the transmitting button,
refer to the garage door opener opera-
tor’s manual.
Step 9:
? Press “training” button on the garage
The “training light” is activated.
You have 30seconds to initiate the follow-
ing step.
Step 10:
? Firmly press, hold for two seconds and
release the programmed integrated
or4).i
The indicator lamp1 flashes the first
time the signal transmitter button is
programmed. If this button has already
been programmed, the indicator lamp
will only start flashing after 20 sec-
onds.
i
If the indicator lamp1 flashes rapidly
for about two seconds and then turns
to a constant light, continue with pro-
gramming steps 8 through 12 as your
garage door opener may be equipped
with the “rolling code feature”.
Step 11:
? Press, hold for two seconds and re-
lease same button a second time to
complete the training process.
Some garage door openers (or other rolling
code equipped devices) may require you to
perform this procedure a third time to
complete the training.
Step 12:
? Confirm the garage door operation by
pressing the programmed integrated
or4).
Step 13:
step 3.
